Chassis Flex: Does it matter?
    • 2020
    #46
    talclipse: With that said I will die on the hill that cars built from 4130 need some form of stress relief/ normalization
    They are when they get powder-coated, least I've had people tell me that. Look up normalization and see if you think 400 degrees an oven might get is gonna get the job done. . .shrugs/smiles
    • Lizardracing
      • Sep 2009
      • 839
      #47
      No.
      Annealing temp are around 1500' for several hours and a control slow temp decrease and normalization/stress is around 1200' for 24 hours.
      450' for 30min ain't doing nothing......Measurable anyway.
      Maybe part of the process is a 12-1500' to bake off impurities first, the coated, then baked at 400 for 30minutes and you have an argument.
      • Austin34471
        • May 2010
        • 174
        #48
        "We here at * ______ Race cars* perform a special stress relief and annealing process in an large oven that is big enough for an entire chassis while using a special coating to prevent oxidation and further material degradation over time."
        Oh so you powdercoated it. Nice.
        • Ghopper
          • May 2008
          • 234
          #49
          It is hard to "like" a comment here. The forum needs to adapt to 2022 and mimic some disruptive social media trends.
          You guys are really getting into the weeds of component details. Tubing thickness and gusset designs are all over the map in this market. Now everyone is guessing on residual stresses like they are talking about dark matter (https://en.wikipedia.org/wiki/Dark_m...ough%20gravity.) Don't most people vibrate at time of weld?
          The answer is to measure the current spring rate of the car, and tune this to be in a window that is determined from objective/subjective feedback of multiple track test sessions. Billet was already doing some of this.
          No dirt chassis manufacturer has contacted me about measuring their vehicle stiffness. I will just end up knowing it for their cars. Cup teams have chassis-only twist rigs to check variability in cars. I was lucky to have a friend that got this rig off FB Marketplace to make it easier find stiffness of the whole car assembly.
          • grt74
            • Jul 2009
            • 1380
            #50
            alot of over thinking going on here, just saying, its more important to just and some bars in a particular area,
              So the real question is.....can it be measured accurately and predictably to enable us to adjust our wheel loads effectively?
              Side note.......Hoffman says he buys 15 chassis at a time. They come in pieces, in a box, pre-bent from a cnc company. His results speak for themselves!
                • 14324
                #52
                You can easily build a test setup. It's not about adjustment. The car is either in a range you know is good or you don't use it. That's what one should do with the data.
                We live in a world though where the chassis is blamed when a guy has something else screwed up and thinks the chassis is wore out. It's expensive, but allows egos to remain intact.
                • grt74
                  • Jul 2009
                  • 1380
                  #53
                  completely agree with this one !!!! ill say this and leave it alone, all chassis take a set per say, thats why you can build 2 cars the same but one is going to run better, put that one on a pull down ,get the numbers the same and there its is (its amazing that we are looking at 1/16th of an inch and less these days) ,now you have the same car (notes are the big key here), of coarse one will always feel a tick better than the other, just the way it is, now the issue with tubing isnt racing the car that is the issue, its when you stuff her in the wall at over 150mph, at that point its becomes a saftey issue, thats why you get mandates from nhra,cup, and others in the racing world, we are getting closer and closer that point, over 150 is a factor and every 25mph after is, thats why youll always see cup under 200 for the most part
                  just my 2 cents
                  consistency is going to be the biggest factor, on all parts, tubing,welding, testing, tweaking, then great notes,
                  hoffman is winning because of his complete package and consistency, not the chassis by itself
                  • Ghopper
                    • May 2008
                    • 234
                    #54
                    I reject this. Change the stiffness matrix of the existing car (which is an assembly of many parts). There are many parts on a racecar that changed after they leave the factory; Tires, shocks, motors are matched to the changing needs of the consumer.
                    How: Maybe you are changing motor mounts, number of bolts in components, adding a brace, cutting a brace.
                      • 14324
                      #55
                      I didn't say you couldn't bring it in.
                        I was hinting at making it easily adjustable........at the track if need be! Theres plenty of super stiff bump springs that could be hidden in the right places.
                        • TheJet-09
                          • Jul 2013
                          • 1616
                          #57
                          Somewhat off topic, but I was curious...how many man hours do you think go into building a chassis (on average) from the first piece of tubing on the jig to ready for powder coat? And having asked that, where do you think the largest percentage of cost in building that new chassis comes from...material (but I doubt that)? The design itself? Labor to build it?
                          And I don't ask because I think I have an answer, I'm truly just curious.
                            • 2020
                            #58
                            Designing car, making jigs, and labor to do that stuff is a lot to recover so that cost has to be spread out into the number of cars your gonna build. The number of hours you have in just drawing tabs, brackets and etc is overwhelming. I know on one of my cars I have over 90 different tabs/brackets and lasered parts just for that one style of car.
                            Material (before stuff got crazy) cost just for the main frame (no bumpers and etc) is gonna run close to 2K if you buy enough to do multiple cars (say 5) and then you have lazered parts, brackets, tabs, and etc (that can easily run 700.00 per car).
                            Time to build a car from raw tubing to finish ready to powder coat: That's gonna very a ton, things like how often you do it and your equipment change that a lot. For example, I've had a guy weld for me before and he's really good and fast as hell. A car all tacked together on jig took him 6.5 hours and then 1.5 hours out of jig to weld underside that you can't get to on jig. I did the same car and didn't keep real good time but I was around 14 hours just in jig part. Course he put his helmet down and didn't lift it until he was done.
                            2 guys working can usually do one in around 40 to 50 hours, if you done a couple before. Again that's no bumpers, fuel cell cages, etc just a bare frame.
                            Honestly frames should cost way more then they do, If a guy was honest.
                            #Note: this is bending the tubing and notching it, nothing CNC'ed prebent and notched
                              Do you think buying cars in a box, CNC'ed, will lead to more consistency in rigidity?
                              • fastford
                                • 4059
                                #60
                                do they have CNC,s that can weld an entire LM chassis ?
