LR limiter
  • dirtslinger71
    • 83
    LR limiter
    Whats the recommendation on starting point for the lr limiter spring? Is the spring better than the rubber puck? I have used the rubber pucks in the past but only because I knew it was better than solid. Never did any kind of load testing with rubber so not sure what the rate is of the rubber compared to the a spring rate... Thanks for any info.
    • 14304
    Spring isn't a great idea. Anything with a single rate can oscillate out of control if you hit the resonant frequency.
    You should also have progressive rate so the "spring" doesn't affect your drop much when it unloads. Say you hit a slick spot, and you lose some traction, if your spring unloads, you instantly lose hike and the corresponding amount of steer. Now you have to react with the steering wheel and the gas pedal, instead of just the pedal.
    • dirtslinger71
      • 83
      Thanks masters. I never would have thought of all that. I just figured you could gain more drop in the LR with a spring was my thought.
        • 14304
        It would, but so would lengthing the chain. If you are worried about droop rule, spring isn't allowed anyway. I hear Lucas and WoO is calling every little series in the country and trying to compel them to adopt the rules. So, you may see it soon. Those jerks don't care that most of us don't care about the stupid stuff they think is important. They don't care that budget guys just trying to have some fun don't want to throw stuff away and buy new stuff, just to comply with a Lucas rule, when they don't intend to race with Lucas. They need to accept they have invented a new LM spec class and just move on.
        • dirtslinger71
          • 83
          I thought my series rules were gonna adopt some of the new body rules and the droop rule but they didn't.
          • Krooser
            • Nov 2012
            • 3117
            Hey MBR... what limiter do you use? Old people want to know!
            Class of 2019
              • 14304
              I have one of those Wehrs cans with rubbers in it, on both our old cars. (The 2 cars do not have the same rubber combo. This isn't really on purpose, I just don't see where one is better than the other.) I may have to throw them away so someone can see what's inside. SMH
