MBH Mastersbilt Rear End/Axle Length
  • kn48racing
    • Apr 2014
    • 12
    Hi all. Just picked up a 2013 MBH close to bare frame for an upgrade. Currently running a Smackdown copy. Current car has 33/35 axles. Will this combo work in the new MBH? I’ve heard people say the MBH cars are basically Gen-X fronts and Smackdown rears but I’m not sure what all that exactly means. Any help would be greatly appreciated. Thank you!
  • phenom08
    • 228
    Yes 22" j-bar, from right side of lift bar plate to center of frame rail 15.75" increase to 16.25" in the slick. Is what mbh papers we have says. Actually will need a 1" wheel spacer on the lr. Because the paper say 34/35 rear
      • 14303
      I think the smack rear comment was based on the 4 link lengths, because as phenom corrected, the rear is a gen x as far as axle lengths. I'd change the tube instead of using a wheel spacer, but that works too. You just have to make note of that inch when measuring from rotors to locate the birdcage.
