Lr stack rates
  • doyle hargraves
    • Jul 2009
    • 158
    Lr stack rates
    Anybody have any experience with stack springs on the left rear when a heavier driver is in a car? Chassis builders basic setup sheet calls for a 75# spring preloaded 1.5 inches at full droop (112.5 lbs). But when utilizing this set up and driver climbs in car it causes car to lose bar angle making car lazy on restarts Went to a 125 spring and car seems to be more predictable and fire better on restarts. I only preloaded this spring about a half inch. Should I set preload to get close to the 112.5 lbs or try to come up with some kind of stack setup? I have a spring smasher but car builder says to use the preload method to set the left rear. Thanks in advance guys
    Just prop it up with a bumpstop. Don't overthink it.
    • crownman25
      • Feb 2013
      • 442
      I can tell you this much them fat boys win races no bs!!!!!!!!
