5th coil shock - single adjustable - where to set ?
  • RacerX10
    • 571
    The set of Integra IDA's that I bought included a 5th coil shock, it's single adjustable.
    Is that a rebound adjustment ? What's a good starting spot ? Seems to have the same 11 or 12 detents as the others, just haven't seen any info on where it should be set.
    Rocket blue/gray .. steel block alum head .. 1350 tires .. generally smaller tracks (1/4 ish)
    Thanks !
    • 2020
    Thanks !
    It should be rebound adjustable, unless some odd ball deal
    More rebound tightens entry, so I would start start around 6 clicks from full stiff and adjust from there.
    There should be a serial number on bottom of the body of the shock and you could call integra and get the recommended starting clicks, but that's assuming someone else besides integra hasn't been into it
    • RacerX10
      • 571
      awesome thanks billet!
      • crownman25
        • Feb 2013
        • 442
        if you hear the motor changes tune up and down you need more rebound the torque arm is bouncing up and down...
