04 Smackdown
  • shawburn
    • 116
    04 Smackdown
    I have an 04 Smackdown with the original style lift bar that bolts to the side of the bell. Running as a limited late. Opinions if this set-up is okay or should I update to the newer style with heims? Thanks
    • 2020
    The typical diagonal link back to rear end style: Will be freer on the gas
    vs
    The typical short link to right frame rail style: Will be tighter on the gas
    Not huge but there^
      We run the birky style that has heims but still braces to the rear. You can upgrade to that if you want. Your old one is probably due to fail at some point.
