I want to make right front brake work very very little. Our rules say no shut off. Any suggestions?
rf brake
You think they will actually look?Originally posted by brett4 View Postall pistons must be the same size and no proportioning valves
1) smaller rotor diameter on rf
2) rf on it's own master cylinder, other 3 wheels on the other one. Put huge supply line on the rf.
3) lower coefficient of friction pad material on rf, or more friction on other 3 corners.Modern Day Spec Wedge Racing
Too add to that:Originally posted by MasterSbilt_Racer View PostYou think they will actually look?
I assume it says you have to have a caliper, so not running one likely isn't an option but does it say it has to be same caliper? meaning can you use a single piston caliper of the same piston size or anything with the same piston size yet with much reduced clamping force?
Instead of #2 you can tee off the clutch line and put a ball valve, that way it doesn't work but can turn back on for tech to show brake works. Obviously this could be dangerous if you forget and apply the clutch and car wants to dart right and with a ball valve is not allowed. However a guy could wire up a electric shut off with a clutch switch to pedal and sort of make this automatic and be under the dash where they wouldn't look for one. Then just flip switch off for tech.
Obviously a smaller OD rotor and getting with a brake manufacturer for a less grabby pad would be the simpler solutions, if you can't do the less clamping force caliper above.
If you meant using a 6 line that expanded, it will make the LF spongy also and likely defeat the purpose.Last edited by billetbirdcage; 01-16-2023, 04:17 PM.
that could act as a check valve , we just put a small nail in the line where it bolts to the caliper , but if tech jacks it up to see if it works , then your screwed , never had that happen though , they just looked every thing over and that was it .....Originally posted by Punisher88 View PostKink the line. Lol
Remove some if the pad on the RF, remove the pad material from the middle to pass visual inspection and wheel spin test.
Even if they removed the caliper, it's unlikely to be noticed.
Dip the RF pads in brake fluid and let it soak in a while. The next heat cycle will glaze them really badly.
Ball bearing and spring under the brake hose AN fitting acts a pressure sensitive check valve. A slow light push shows everything works perfectly. A litte harder and faster and the ball and spring close and prevent the some or most of the fluid from moving.
