front wheel weights
  • vms
    • Mar 2011
    • 84
    front wheel weights
    Would you say that almost havin the same weight across the front is good or bad. How does it effect the car?
    How about the cross percentage what will this do?
  • jedclampit
    • 613
    If your fronts weigh the same, then your left side and cross are the same.
    • vms
      • Mar 2011
      • 84
      Is this good or bad
      • racin6mod
        • 2172
        if this is for a rayburn thats not bad CJ had me set ours as close to even as possible.but we had plunty of lr and the car was close to perfect at our local track.
        • Graff Spee
          • 881
          I will be honest, I have never looked at the front weights. It will change with the spring selection anyhow. Good luck though.
          • F22 RAPTOR
            • Jul 2010
            • 1023
            Way to go.
            Equal fronts is how we always setup our cars, going back to Frank McClendon at Custom Chassis in the early 80's. I did the same when I went kart racing for a while. On some tight cornered tracks I like a little more LF to help rotate the center better. I say equals is a good thing.
            "If racing were easy, everybody would do it."
            #77 Leon "Slick" Sells
            • vms
              • Mar 2011
              • 84
              great
              Well the car handled very well for a driver with little seat time in a latemodel.
              • gadirtracer
                • Dec 2007
                • 1039
                Now that I read this post, when scaling my car, I have a LF that is about 200#'s heavier than the RF!
                Gill T. Azell
                • DLM06
                  • 69
                  How would the weight change if the ride heights were set correctly with the spring change?
