Rf chain
    Rf chain
    I saw one on a new Harris mod. Are they being used on any dlms?
    • 14303
    If you need one, something is seriously wrong. That's all I got to say about that.
    • Kromulous
      • 3008
      Softer spring with Preload on Mods, so stopping the droop helps getting the shock off easy. Since the spring and shock are seperate. The geometry of the clips produce a lot of droop travel thats useless.
      Just say no...
        Youre probly right, it had 4-6 inches of adj.
        • outlaw4j
          • May 2012
          • 72
          it might be seriously wrong...but those harris cars are seriously fast. currently leading imca national points and won the USMTS opener
            • 14303
            I was addressing the use on a late model, specifically. The non-racing use on a mod makes sense.
            • 7uptruckracer
              Using them on alot of stock clip applications, it’s a way to run soft but still have some rate in your 1-2” travel range so you don’t crash through your travel. The spring acts stiff until it overcomes the preload in the chain. It’s the same concept as like a Joes Racing Preloader.
                • 14303
                ^^your spring is actually rated at infinity, until your preload is overcome.
