Odd question... Radiator Cap
  • Underdog
    • 240
    What radiator cap should I run with my 604 crate late model?
    20-22lbs. Or
    23-25lbs. Or
    29-31lbs. Or
    31-33lbs. ???
    Any/all input welcome, thanks, KB
    • 14303
    As much cap as the rest of your system can handle as far as pressure goes. It should be the weak link in the system.
      • 2019
      Agreed. On a side note, with higher pressures make sure your hose connections have a good bulge or ridge on the component or you can blow a hose off.
      • Underdog
        • 240
        Thanks guys
        • Jking24
          • Oct 2017
          • 1512
          Originally posted by Underdog View Post
          Thanks guys
          Every psi raises the boiling point roughly 3°f so the higher the cap the hotter you can run before melting it down
          • SlicktoSlime
            • Sep 2021
            • 16
            Keyser sells a 38-42 we have been running them for a few years.
