1997 warrior z-link,what do i need to measure off of to get square front to back and side to side?
how do i get my rearend square?
Not sure on the Warrior but most rear ends are not square in the chassis on a dirt late model. The left side will be shorter and the rear are will be shifted to the left.Originally posted by mignum View Post1997 warrior z-link,what do i need to measure off of to get square front to back and side to side?
Once you get it were you want it. you candrill referance holes in the frame to measure off of next time. Make sure you put at least four holes(1/8 inch drill works good) You can then do a quick check if frame is out of square also.
