RF Upper Control Arm Angle
  • Cranky
    • Sep 2014
    • 174
    Is it better to have your RF upper control arm fairly flat at ride height to help gain some negative camber in and out of the corner or have a bunch of angle upwards towards the ball joint and a more aggressive negative camber starting out?
  • Jim11h
    • 1501
    Pure speculation but I'd think closer to level because ball joint can only rotate so far till things bind. So extreme angle upward I think is bad
      • 14319
      The correct camber curve beats looking at one individual piece. In a perfect world you'd probably want constant camber with relationship to the ground thru all chassis movements.
