My Rocket set up what do you think
  • vms
    • Mar 2011
    • 84
    The car is a older rocket, heres what it has on it right now.
    Front weights:
    left 555 right 523
    Rear weights:
    Left 736 right 555
    Percentages:
    cross 53.1%
    rear 54.5%
    Left 54.5%
    Bite 170
    Stagger:
    4" rear and front 1"
    Shocks:
    LF 763 RF 735
    LR 963 LR 955
    5th coil
    733 300 spring
    Springs:
    LF 500 RF 400
    LR 225 RR 200.
  • gadirtracer
    • 1039
    Take 100lbs of bite out & swap the rear springs.
    Gill T. Azell
    • C10
      • Nov 2008
      • 359
      Rocket recommends 150 on bite and as the last poster said swap the rears
      • 4bangerhotrod
        • 374
        you said you have 170lbs of bite but your #'s show 181lbs and thats way to much i would back it down an start with around 120-140lbs
        • vms
          • Mar 2011
          • 84
          I was wondering what swapping the shocks would do? When i was thumbing through the rocket book it has the lighter spring on the RR
          right my math was off.
          • jedclampit
            • 613
            What engine, track configuration, year car,tire rule, black or blue?
            • jrkracing54
              • 620
              I have always ran a slightly stiffer spring in the left rear than the right rear. I have never tried it the other way. Closest I have been is equal in the back. Right now I have a 225 RR and 250 LR in an 03 black front car.
              — Heraclitus
              • vms
                • Mar 2011
                • 84
                358 steel block engine, dr21 tires, 96 black front end said to be updated to a 01. has the 6 hole lower rod mounts
                1/2 mile va motor speedway, wide corners
                3/8 mile dixieland speedway, narrow tight track
                • talclipse
                  • 738
                  As others have said thats way too much wedge. With a limited motor as it sounds you are running you won't have the power to drive through an exit push. I would go down to ~100lbs wedge and as others have suggested swap the springs.
                  • jedclampit
                    • 613
                    Wow, that's an classic car!
                    I don't have any experience with pre 2000 cars.
                    Something I would question is the condition of the chassis tubing, on the INSIDE.
                    I have cut up some old racecars, and the tubing was pretty badly corroded and deteriorated ,yet looked cherry on the outside.
