I understand there is alot of options as far as shocks and springs . But for the dry slick what is the best known that will put drive in a double swingarm . Side bite isn't bad but just struggles getting forward drive . Thx
Forward bite with a Rayburn ????
There have been some discussions about this already, search around a little and you should be able to find it. But basically you get more drive in rayburn by moving pullbar out to drivers side, drop lr bar down, rr bar up, lower j-bar/straight bar on both frame/pinion, if running purple bar go down on the frame. Soften right side springs to let it roll more.
