Water in Gas ?
  • Racer111
    • 796
    Water in Gas ?
    Is there anyway to check if there is water in your fuel ? I know years ago at the gas staion we had a putty we put on the end of the stick to check for it.Found a white chalk on bowl bolt and also on inside of bowl ? Car had a miss in it.Thanks for any help..
  • scrub_fan
    • Feb 2009
    • 139
    when we had water the fuel filter was rusted you could check that
    • Racer111
      • 796
      Checked that no rust.
      • Graff Spee
        • 881
        Try a water seperater for a boat. Use an extra electric fuel pump to filter fuel. Than put back in tank. It should work.
        • JCSullivan00
          • 1418
          The only way to accurately test your fuel would be to find someone that has a hydrometer.
          • walter01
            • Oct 2009
            • 26
            Any water in your fuel will settle to the bottom of your cell.. shake or stir your cell so the fuel is mixed up well. Then siphon some fuel out to fill up an empty clear pop bottle half way. pour in a few ounces of alcohol and shake. The alcohol will absorb the water and settle to the bottom. You will clearly see if theres water in your fuel.
