forward bite help
  • 75t
    • Jul 2009
    • 61
    forward bite help
    we have a 2008 masterbuilt chassis it is awesome in the mud just need a good slick track setup to help forward bite any suggestions thanks.
  • dirtdiggerracing
    • Jan 2008
    • 153
    i had a 03 that was same way . itryed everything never did get it very good in slick . got a 07 now and it is totaly junk it wont even go in the tack !!! i know what you fighting what kind of setup you got on it?
    • dchamp3
      • 193
      What springs,shocks and the track size and banking?
      • 75t
        • Jul 2009
        • 61
        we run a 1/3 mile semi bank track. it has 500lb on lf 450 rf 250 lr 225 rr, also we are running integra cannister shocks. we have 52% on both the rear and left side weights with about 95 to 100 lbs of bite
        • joedoozer
          • 745
          52% rear might be a little low, unless its a crate engine. We run 1/2 mile tracks and my Warrior was just blowing the tires off the car for a few weeks. Moved the 5th coil out to 36" so it didn't hit the tires so hard.....problem solved for me. Something to think about.
          Crew Chief "Tip of the day":
          • 4bangerhotrod
            • 374
            my advice would be to sell the car and get a genX car, from what ive seen the genX cars def dont lack any forward bite. i never have liked anything about the smack cars, i dont even like to watch them go around the track.
            • dchamp3
              • 193
              Get the rear percent up to atleast 54% ,How does it handle in the slick?
              • 75t
                • Jul 2009
                • 61
                forward bite
                its good coming into the corner, the middle off it needs more drive
                  Get the rear percent up to 54%. Put a 350 lb liftbar spring on at 36".
                  The Smack cars are just fine.
                  • 75t
                    • Jul 2009
                    • 61
                    thank you to all
                    • dchamp3
                      • 193
                      MasterSbiltRacer beat me to it but he is right do what he says it will work.
