On one of the tracks we race at we have been fighting an entry push (on or off the gas). We've got the bars in "by the book" position for tacky track which should help it turn. Our springs are LF-500, RF-450, LR-225, RR-225. 54.5% left, 53.8% rear, 80 lbs of bite. J-bar is 1/2" above pinion on pinion side and at 8.5" on frame. Ballast is mounted in reasonable locations that shouldn't be causing the issue.
This track is much higher banked than other tracks we run. We normally run a 425 RF spring at other tracks but it bottoms out at this track so we switched to the 450 which should also help us turn on entry I think.
We were finally able to get it to turn good on entry by moving the lower right bar ALL the way up but this seems like a crutch to me since that is an extreme setup and this is when the track slicked off so I really don't know if that would have worked earlier in the night. Is there anything I am missing for a high-banked 3/8 deal that is causing our problem? Do I need to try raising the entire j-bar a little bit? For what it's worth, the entry push gets worse and worse as the race goes on but we aren't overheating any of the tires and they appear to be working good.
