Looking at a Mastersbilt chassis serial number #203 Anyone have a clue as to what year? The guys thinks it's a 01-03, said it was a 2" square tube car, but didn't think it was a Smackdown chassis. Can anyone pass down any information and what would I be able to update this too. Any info would help its a bare chassis so I'm going to need everything dunno where to start I know you guys are the best so thanks for the help!
Mastersbilt Serial Number Identification
I had a 2000 Narrow chassis with number 269 or something like that. Most likely you have a piece from somewhere around that time. It would take some photos and/or measurements to try and figure it out for sure.Originally posted by 7uptruckracer View PostLooking at a Mastersbilt chassis serial number #203 Anyone have a clue as to what year? The guys thinks it's a 01-03, said it was a 2" square tube car, but didn't think it was a Smackdown chassis. Can anyone pass down any information and what would I be able to update this too. Any info would help its a bare chassis so I'm going to need everything dunno where to start I know you guys are the best so thanks for the help!Modern Day Spec Wedge Racing
should be late 2001 or early 2002. I own #0347 which is a late 2002. Info from Keith masters was they started numbering them late in 2000 and were building between 150 and 200 chassis per year.
Is it worthwhile to update? Would probably be a crate car or a production head engine like our LM run here with a 500 2bbl holley and edelbrock intake. What updates should I look at? What rear end does the masters run, and all that stuff? Do they have spec sheets I can find all this stuff on?
If it has been stored inside, not drilled too much, and so on the cage might be safe. If the cage is safe and it is a narrow car, I would raise the right side rail, put the newest Smackdown geometry on the car and run it.Originally posted by 7uptruckracer View PostIs it worthwhile to update? Would probably be a crate car or a production head engine like our LM run here with a 500 2bbl holley and edelbrock intake. What updates should I look at? What rear end does the masters run, and all that stuff? Do they have spec sheets I can find all this stuff on?
I guess it depends on if you are doing the work yourself and other factors to determine how much cheaper it would be for you.Modern Day Spec Wedge Racing
So what would you have to change in to convert it to the latest smackdown geometry? Do you raise the whole RS rail and whats updated on the front and rear? Ballpark on how much it would be to get a dealer to do it?
take it to Tater Masters in West Virginia, (MB by Huey)
I would probably put the Gen X front end on it.I think there should be lifeguards in the genepool.
Hi I bought a late model and the guy wasn't sure what brand it is he thought it was a mastersbuilt or warrior around 1999 or 2000 could you possibly give me anyway to help determine the brand of the car I know it is completely round tubing which I was told that mastersbuilt didn't start using until later...any help would be greatly appreciated
