rr springs
  • lpd1
    • Mar 2011
    • 104
    rr springs
    what is the most commom used rr spring people use in the real hard slick tracks befor it turns black to keep the car from sliding out??? we have tried about everything and i cant say that i could tell a defference from night and day between then we run a #225 about all the time, tried a 250 a little and didnt see any gains, last year in a old rocket ran a 200 and it was decent but have not tried in on the new frontend rocket?
  • fox1162002
    • 131
    I have used several different combos and 225 is mainly what I use too. Ive ran a 275 to gain side bite going in but it will free you up coming off. But with a good set of shocks you can do more fine adjusting with them and make better gains.
    • timmayb
      • 267
      From what i've gathered the new stuff is pretty loose in general with Rockets. I'm not sure if you're looking in the right place, from what i see all of them have the LR skyrocketed in the dang air, which in turn would cause alot of weight transfering over to the right side. Try adjusting drop and see if you can get the same results.
      • lpd1
        • Mar 2011
        • 104
        try less drop????
        • timmayb
          • 267
          More, what are you running currently?
