Power steering locking up
  • mudderfudder
    • Aug 2008
    • 264
    we have an appleton rack with the intergrated servo, sweet steel pump, pullies on motor are both same size. The rack has been rebuilt been throu 2 pumps and still power steering keeps locking up intermitingly. is it possible that the issue is from the pullies on the motor and we should goto a bigger pulley on the water pump and smaller on the crank? any ideas would be greatly appreciated. Thank you in advance
  • charcoal01
    • 545
    Locking up or chattering? I had a similar problem, I think I solved it by switching from a steel pump to aluminum, along with a couple other changes. I think the rpm rating on the steel pumps is 6500 and the aluminum ones are good to above 8000, though I may be wrong.
    • sj valley dave
      • 1016
      When we ran our aluminum pump of the front of the engine we had a 50% reduction set up, and now with our dry sump we run it off the back of the dry sump and it is a 50% deal also. This is with a KRC pump and Appleton rack and have had no problems....
      • jedclampit
        • 613
        Is it mechanically locking up or just a loss of power assist?
        • mudderfudder
          • Aug 2008
          • 264
          fixed the problem....went to a different style belt and it fixed it plus we decided to run hydrolic fluid.
