valve lash
  • vms
    • Mar 2011
    • 84
    valve lash
    Does anyone know the order you can do the two valves at the same time. #1 intake and #4 exhaust etc
    Set #1 to TDC and adjust intake on #2 and exhaust on #8
    Rotate 90 degrees (get #8 to TDC) then adjust intake on #1 and exhaust on #4
    Rotate 90 degrees (get #4 to TDC) then adjust intake on #8 and exhaust on #3
    Rotate 90 degrees (get #3 to TDC) then adjust intake on #4 and exhaust on #6
    Rotate 90 degrees (get #6 to TDC) then adjust intake on #3 and exhaust on #5
    Rotate 90 degrees (get #5 to TDC) then adjust intake on #6 and exhaust on #7
    Rotate 90 degrees (get #7 to TDC) then adjust intake on #5 and exhaust on #2
    Rotate 90 degrees (get #2 to TDC) then adjust intake on #7 and exhaust on #1
