right rear overdriving
  • rubbinsracin
    • Aug 2009
    • 668
    measured tonight, 6 1/8" if the RR is tucked way up using a fully compressed 7" shock as a stop. so that is well beyond where any normal 9" RR shock with a spring would let it go. so i put the my normal RR shock/spring and tire on the ground and put the jack in front of the LR and took the tire off and jacked the car all the way up and then i had my dad, who weighs about 230 on the RR of the body above the tire and pushed down. I then put my brother. who weighs about 230 as well on the RF frame rail to cause it to simulate roll. i made took my measurement, 5 15/16 puts me right on the frame with just a glimmer of light in between the axle tube and the underslung rail. so im thinking the car is right in the ball park.
    another question, my RR 4 bars with the car at ride height go straight back from the frame to the birdcage. and my left side bars run slightly out, meaning the frame side is further in than then birdcage mounts, in other words the bars are further towards the outside of the car on the birdcage side. i have never noticed this before. the driveshaft is completely straight, from tranny to pinion. so im thinking i need to just move the left side birdcage in just enough to bring it to straight. is this correct and i am just over thinking this or is there something i am actually missing?
    • Bcollins82
      • Jul 2009
      • 322
      Repeatability
      You have no way to repeat your measurements. This is the reason all chassis builders have you check droop with both sides hanging. I'm guessing when you check it like that your not dropping far enough. If your at the track, or even back at the shop it's not very likely you'll be getting consistent measurements by doing it like that. And on the LR bar toe, we've normally run the bars (left and right) toed in slightly, but Shaw should have a left to right measurement for you. It's usually a measurement from the lift arm to one of the frame rails.
      • rubbinsracin
        • Aug 2009
        • 668
        im not so much worried about the drop, considering we are running good now and we only have 5 races left this year, its not worth making changes and chasing my tail for the remainder of the year.
        we have the measurements for centering the rearend and it is centered correctly. and like i said the right side bars run straight back. but the left side moves toward the outside of the car as the bars go backwards to the birdcages. but what would moving the left side bird cage in towards the center of the car about 1/2" to 5/8"(not sure on the exact measurement it would take) do to the handling? i know it would stand the shock up maybe a degree or two which would make it react heavier right?
        • Bcollins82
          • Jul 2009
          • 322
          Getting the drop correct is an essential part of making a spring behind setup work. It's overlooked too often and if you don't have it right can cause exactly the problem your describing. As for the LR birdcage being moved in to straighten up the bars or toe them out, I was told by Tader Masters to move ours inboard like that before to stand the shock up and actually slide it in far enough that the bars were pointing left so they straightened up when the car hiked and rolled. That adjustment was supposed to tighten the car up on throttle, but we noticed very little change by doing this.
          • rubbinsracin
            • Aug 2009
            • 668
            im not sure what problem you are talking about. im not the OP and dont have problems with the RR over driving. i just got in the convo talking about ways to help with it. im fairly sure that my setup is pretty much spot on. if there is anything holding me back, its the fact im still learning to be more consistant with my driving. ive been a part of setting these cars up for about 10 years. but am still new to actually driving them.
            • Bcollins82
              • Jul 2009
              • 322
              Lol my bad.... Got confused thinking u were OP.
