I checked how my tracking is on my GRT...It seems to track more to left side. I straightened LF wheel and ran a string down left side,with the string touching front and back of LF wheel,the LR wheel is inside the string about a 1/2 to 5/8 of an inch. I have the J-bar Bracket 8 3/8 up on chassis in third notch and J-bar second notch up on pinion,and J-bar length at 19 1/4 inches. Does all of this seem correct? The driveshaft seems to be in-line at ride height...seems to me it should track a little more to the right. Any help will be greatly appreciated
GRT Help
The RR should be in about 4 inches closer to the center than the RF depending on the year of the car, the left side should almost line up.Originally posted by mqdirtracer57 View PostI checked how my tracking is on my GRT...It seems to track more to left side. I straightened LF wheel and ran a string down left side,with the string touching front and back of LF wheel,the LR wheel is inside the string about a 1/2 to 5/8 of an inch. I have the J-bar Bracket 8 3/8 up on chassis in third notch and J-bar second notch up on pinion,and J-bar length at 19 1/4 inches. Does all of this seem correct? The driveshaft seems to be in-line at ride height...seems to me it should track a little more to the right. Any help will be greatly appreciated
The left side almost lines up.The LF is outside the LR about 1/2-5/8" so,I am gonna say it's pretty darn close. Thanks Ego!!
