shock in front of axle on GRT????
  • hobbyracerbn2
    • 113
    Im goin to a split valve shock on the lr behind axle with a 6/2 shock.. what shock valving would be most recommended to run on the front of axle mounted on the birdcage with the 6/2 shock? track stays sorda tacky to little dry with a little rubber,groove is on the top most of the time Thanx
  • sj valley dave
    • 1016
    Never ran a shock in front with our GRT. when we ran twin tubes we ran a 9/3 behind axle, and with the mono tube we run it by itself behind axle..
    • pcope98
      • Jan 2009
      • 225
      ill second what dave said i have run there cars for about 7 years never ran a shock in the from just a 6-2 like your doing or the 8-3 deal
        For some reason everyone thinks you can't run a shock on the front of a GRT. I call BS.
        • hobbyracerbn2
          • 113
          I appreaciate the help guys on the Grt Info..Umm just askin if yall know how far to mount the grt birdcages on the axle?? I dont want to get anything misalligned..And on J-Bar do u let the rearend all way down before u adjust ur j-bar for side to side??thanx
          • GRTLRBITE
            • 787
            this lrft shock is a good one. we run an lr ft shock on our GRT
            • jedclampit
              • 613
              I second that BS!
              • stevo
                • Jun 2008
                • 622
                Don't you just need it in the mud?
                • hobbyracerbn2
                  • 113
                  yea but what valving would u run on the front with a 6/2 shock???
                    Probably a 4-0 or something in that ballpark.
                    • hobbyracerbn2
                      • 113
                      ok i believe i have one,but what does this do?? i mean i seen people run it but had no clue what it does?
                      • jedclampit
                        • 613
                        I've used as high as 9-0 at slick big corner,momentum tracks, with certain drivers.
                        4-0 to 6-0 is commonplace.
                        Helps keep the hiked attitude in the car, when you have to be out of the gas longer on entry, slicker tracks, and drivers who don't have trail braking really figured out, usually need more compression.
                        Helps control hike down, which usually causes the car to get real tight from the quick loss of rear steer, and lack drive when back on the gas.
                        • hobbyracerbn2
                          • 113
                          more less keeping the car free goin into corners??? what else would i be expecting from this setup??? More loose all the way through or tight??? And do i need to change anything as far as percentages of scaling?? or how much bite for a GRT for this setup??
                          • jedclampit
                            • 613
                            Don't expect a major change (unless your car darts w/a push/hikes down when you lift) ..................expect consistency!
                            Notable changes CAN include:
                            extended side bite on entry
                            better forward drive off
                            mostly more consistent lap times/control in traffic.
