use this and will my car help turn in middle of corner???
rf brake shut off...
The only thing I use it for is to keep the RF from locking up in packing laps. I don't think I would want to use it to rotate the car though.Crew Chief "Tip of the day":
I use it a lot. It is a bit of a crutch but.. it is an effective crutch.
It will help the car to rotate whenever you use the brakes. Whether you give them a slight touch in the middle of the corner to help with rotation, drag them coming off the corner to control wheel spin and rotate, or stab them down the straight away because of something happening ahead of you. The car will rotate.
I wouldn't use it unless it's tacky and you're goin out for qualifying. It jus turns the car/rotate whenever you touch it. If you have it off and theres a wreck in front of you goin down the straight and you have to jump on the brakes, well.....the car will turn left pretty hard. If you need it to help the car's handling issues, I'd personally try to change the setup to help the car turn. My car has the rf valve shut off, and I've never touched it. JMO
I don't care for it myself and wouldn't use it to fix a tight middle issue. We race on a dry slick track and it causes the car to over rotate and isn't beneficial at all on that type of track. I use it in hot laps or if the track is SUPER heavy. If the track is just tacky I still use 4 wheel and never use it on a dry slick track.
But every driver likes a different feel.
I agree, the only time we used it is when the track was sloppy wet mud.Originally posted by HuckleberryB4 View PostI don't care for it myself and wouldn't use it to fix a tight middle issue. We race on a dry slick track and it causes the car to over rotate and isn't beneficial at all on that type of track. I use it in hot laps or if the track is SUPER heavy. If the track is just tacky I still use 4 wheel and never use it on a dry slick track.
You can get away with it on a slower track, but I wouldn't plan on using it all the time. I consider it a last resort when your car is really bad.Modern Day Spec Wedge Racing
its a in (not a nice word)(not a nice word)(not a nice word)(not a nice word)pit tuning tool. Our driver had it on majority of the time. And always had all rear brake. If he came in and had front brake cranked in the car we were going backwards.
Each driver is different and you will just have to try it to see if you like it.
The best driver I ever CC for did the same, with same resultant, front brake meant loose car, heading back thru the pack.Originally posted by powerslide View Postits a in (not a nice word)(not a nice word)(not a nice word)(not a nice word)pit tuning tool. Our driver had it on majority of the time. And always had all rear brake. If he came in and had front brake cranked in the car we were going backwards.
Only used it when car wouldn't turn at all. Found out after race the LR brake rotor broke off the hub so I didn't have but one rear brake...which is why it wouldn't turn. Otherwise I use it as a parking brake when I'm on inclines waiting to go out on the track.Web: http://www.t17.co
If you're running a spooled rear end, that doesn't make any sense. It doesn't matter what side the brakes are on, both wheels will have the same braking potential. They are locked together. If you are running something besides a spool, different story.Originally posted by merc123 View PostOnly used it when car wouldn't turn at all. Found out after race the LR brake rotor broke off the hub so I didn't have but one rear brake...which is why it wouldn't turn. Otherwise I use it as a parking brake when I'm on inclines waiting to go out on the track.
Matt - I see where you are coming from about the spool and the wheels being locked together, but if you only have one caliper as opposed to two calipers clamping down you wont have the same stopping potential as if you were to have both rear calipers functioning correctly.
Very true.Originally posted by rubbinsracin View PostMatt - I see where you are coming from about the spool and the wheels being locked together, but if you only have one caliper as opposed to two calipers clamping down you wont have the same stopping potential as if you were to have both rear calipers functioning correctly.
Putting that little tidbit back in the back of my mind though. Never though about the spool effect with the brakes but I was going to bring up the same thing as rubbinsracin about actual stopping power was decreased.Originally posted by Matt49 View PostVery true.Web: http://www.t17.co
