06 masters spring heights??
  • 35racing
    • May 2008
    • 102
    Is a 12" spring the correct height four all four corners? Can you run other size (height) springs in all four corners? Im running a stack spring w/lock nut on the LR 14" primary and 4" secondary, 14" RR and 12" on both LF and RF. One problem Im having is the LF with the take up spring is out of adjustment room and ride height is close but still a little high. I have a 10" spring I could install if this is okay??
    Im not sure if my other corners are causing any other issues that im unaware of..
    525LF 400RF
    200/600LR 225RR .............any opinions on spring package?
  • dchamp3
    • 193
    lf 10'' rf 12'' lr 14'' rr 12''
    • JAMESGANGRACING
      • 192
      Keith told us 10's on both fronts
      • rubbinsracin
        • Aug 2009
        • 668
        we run 10s on the front and 14s on the rear
        • jedclampit
          • 613
          Ideally you should run the shortest spring you can and have adjustment available, without any coil bind at maximum useable wheel travel.
          The longer the spring, the more weight and possibility of bowing/rate inconsistency.
          Find a happy medium based on what YOUR car shows it needs with the above criteria.
          This varies with setup and coilover spring mounting points with different coilovers.
          • 35racing
            • May 2008
            • 102
            Okay, Thanks guy's!
