Stacked Springs
  • Sprint76
    • Aug 2008
    • 76
    #31
    Chumba, clear your PMs.
    • mackwrench
      • 449
      #32
      STACKED SPRING RATES
      400 / 175 = 122
      400 / 200 = 133
      400 / 225 = 144
      400 / 250 = 154
      400 / 275 = 163
      400 / 300 = 171
      400 / 325 = 179
      400 / 375 = 194
      400 / 400 = 200
      Formula:
      Top spring Top spring
      X (divided by) + = Total Spring Rate
      Bottom spring Bottom spring
      Example:
      400 X 225 = 90,000
      400 + 225 = 625
      90,000 divided by 625 = 144
      www.freewebs.com/circlebracing
      • CHUMBA
        • 133
        #33
        PMs cleared, I think
        • rcmaster
          • 67
          #34
          you guys have alot to learn, hypercoil will get you lentgh you need, get you a checker and check stack rates with different nut settings,you will be shocked, and when you run it make sure you have a travel indicator on outside of shock.
          • CHUMBA
            • 133
            #35
            Teach us old wise one! thats why Iam asking questions on here trying to learn, dont have budget to travel 4 hours rent track and just try things, I have called chassie builder, he dosent run it. and wont give advise on it! PM me if your are interested in helping. CHUMBA
            • rcmaster
              • 67
              #36
              not trying to be smart,it just takes testing, every driver is different,how much rebound you run in right front makes huge difference, most people will try it and run it if it works that night if not they wont adjust it just take it off.one last thing figure out how much rf travel your car gets when its at its best then make sure your stack gets same travel then adjust to liking--------- its really difficult to explain all the different adjustments.
              • CHUMBA
                • 133
                #37
                Not calling you a smart ass!!! Just trying to get as much info as I can. we have ran it our last three races, and are going to continue to work with it, I think we have figured out we are running too much gap, thats the only direction we have been adj, when we start raceing again we are going to go less gap, but that will be in april 2012. so Iam just trying to learn more about the complete set up so we can be close. thank you for info, and again sorry for implying you were a smart ass, not my intention!!
                Chumba.
                • BDR40
                  • 77
                  #38
                  A lot of guys run around a 400-600# 4 inch spring with anywhere from a 350-450# 8 inch spring on the dual stage stuff. Brian @ Integra recommended that we start with a 600/400# to start out.
                  • CHUMBA
                    • 133
                    #39
                    thats funny 2 years ago I ask him about doul stage stack spring on right front and he said he knew nothing about it. that was after I spent around $1000.00 getting shocks repaired & revalved.
                    • Ltemodel
                      • 307
                      #40
                      We start at a 600# top and 400# bottom and put 3/8" to 5/8" gap in the lock out ring at ride height. The best way to figure gap, if you can't test, is to record your RF dynamic ride height with your slick RF set up in. Usually you will soften RF for slick. Record your compression travel on the RF.
                      Record your shock eye to eye measurement at ride height.
                      Take your spring and shock off the car and put it into a spring rater and compress it to ride height and then dynamic ride height and record those two load readings.
                      This will give you the load the spring is supporting at its maximum in the corner and load at ride height.
                      Then stack up your springs with the lock out and adjust them so that your spring eye to eye measurement and your load at ride height come back to the original measurements.
                      Then you can compress it and start playing around with the dynamic side.
                      If you want to raise the RF ride height in the middle of the corner, take gap out of your lock out adjuster.
                      If you want more travel on to the RF before it stops, put a larger gap into your RF setup.
                      This set up is not a cure all deal. It is good if you know how to work with it. Experiment and have fun.
                      Kevin
                      Check out my book on Amazon.
                      My YouTube Channel
