Frankland vs Winters
  • citiracer
    • May 2008
    • 233
    What are some opinions on the differences in these two rear-ends?
    Looking specifically at durability and performance. I won't say cost is not an issue but I'm willing to pay more for the Frankland if there is a tangible improvement in either durability or performance.
    P.S. For reasons beyond my control, these are my only two options.
    Thanks!
  • hucktyson
    • 1903
    Here the differance you can run a winters for 10 years if you run good synthetic lube and the ring and pinion look brand new and you can run a frankland 10 races and the ring and pinion no longer look brand new. I would be willing to bet when you see a car fall out of a race with rear end failure its probably not a winters that broke
    • SS Motorsports
      • Sep 2008
      • 431
      have used both and had zero problems with either brand. The main thing to know is where to actually fill it to. And spend money on good oil ie: mystik or whatever brand you prefer. A brand new Winters, Frankland, Bulldog etc.... will do you no good if you buy cheap gear oil in a 5 gal. bucket that has no recognizable brand on it just to save a dollar.
      • cbracer14
        • 41
        Make sure if you choose a Franklin.... it is one that has a pinion support in the case......
        • fastford
          • 4059
          ive been running the same frankland center and quick change since 2001,had to replace one bell a few years back due to a crash, but every thing else is original and all thats ever been in it is plain castrol gl5 fluid, its still good as new with at least 10,000 laps on it
          • hucktyson
            • 1903
            Are you running a stock 305 by chance ?
            • fastford
              • 4059
              ford never made a 305, however we run a 2.3 pinto engine which has a good bit more power than a 305
