Bert leaking oil from vent
  • jbtill12
    • May 2008
    • 229
    Bert non-ball spline transmission is leaking oil from vent tube at top of housing. What could be causing this?
  • SLM98
    • 407
    Every one I owned did this, pull vent tube,tap with 1/8 pipe tap and put in a hose barb fitting with a two foot piece of hose zipped tied up high on cage with a inline fuel filter on end: no more leak
    • redfred
      • May 2010
      • 154
      It's probably over full. You should be able to remove the side plug and the level should be about 1/4 inch below the plug.
