I've been doing some thinking on this and I had some thoughts I wanted to run past my fellow 4Mers.
With as much rear steer as we are able to get with today's setups and the fact that there is almost always a certain amount of wheel spin, I'm beginning to think that tuning stagger to loose versus tight is a flawed thought process. I'm hypothesizing that the ideal stagger is the stagger that generates the rear wheel camber that creates the most consistent tire temps and wear across the surface of the rear tires.
I know, I know, everyone is going to say that increasing stagger always makes the car looser and I'm not necessarily disagreeing but I'm questioning the real reason WHY it makes the car looser. In my hypothesis that would be because as you increase stagger and hence increase positive camber of the LR and increase negative camber on the RR, you are decreasing the effectiveness of the contact patches thereby decreasing traction in the rear tires (which makes you looser).
My hypothesis could further then state that at some point decreasing stagger from the ideal stagger could also loosen the car but I'm not prepared to defend that statement just yet.
Just wondering what others' thoughts were on this and if anyone here has done any extensive testing in this area.
