Tips to "winterize" Alky Engine?
  • Rocket_racing
    • Oct 2009
    • 44
    We only got out 6 times this season on our fresh engine. What are some tips to keep the engine onver the winter so it is ready to go next spring?
  • Racer111
    • 796
    back off rockers and turn engine over from time to time over winter,Drain carb,fuel pump,regulater and fill with transmission fluid.remove fuel filter or the alky will eat it during the winter,Clean fuel lines with gas.drain fuel cell.if car isnt in heated area drain water out of block and rad and add a little antifreeze just in case theres water sitting in corner of block after draining..
    • 31KMOD
      • Aug 2007
      • 642
      I would "fog" it tranny fluid, as well as the things listed above
      To bad people that know it all can't do it all!
