best fuel pump for gas
  • spiderma4
    • Dec 2009
    • 91
    wanting to know what would be the best pump for gas running 438 sb2? i am running a race pump block style now and when running the mains the longer the laps it seems to start to lose power. sometimes fuel pressure drops down like when iam staging and wont move unless i shut off the motor and restart it.
  • hucktyson
    • 1903
    cv products/spin 2508 with dead head style regulator, the fuel pressure never moves
    • joedoozer
      • 745
      I have been running this pump.
      And this regulator.
      I set it at 6 psi and haven't had a problem this year. The needle never moves and if it does, there is a problem.
      Crew Chief "Tip of the day":
      • hucktyson
        • 1903
        And this regulator.
        I havent come across a single engine builder yet that asks for 6psi they all ask 7.5 to 8 for gas, and thats cornett, clements, russel baker and a few others over the years. And guess what else ?? They all use the spin/cv 2508. Yes there more expensive but they are rebuildable and they last (not a nice word)(not a nice word)(not a nice word)(not a nice word) near forever. The guy didnt ask whats the cheapest thing that might provide enough fuel to not burn pistons , he asked whats the best pump for gas. from there you have race pump which i have herd soooo many horror storys i wouldn t even consider it, you could use an aeromotive belt belt drive which can supply (not a nice word)(not a nice word)(not a nice word)(not a nice word) near anything but you risk losing a belt and not finishing the race and you have the cv products stuff which almost every major engine builder uses exclusively. If you have a $5000.00 motor you use a 150.00 fuel pump if u run something that makes big time power and you spent a lot of money on it cv is the only way to go
        • Egoracing
          • 4852
          Really depends on what block you are running. Does it have a mechanical fuel pump boss? Do you run a trans with a drive off of it? The BEST is a rear mount belt driven pump if you can run it.
          • manwplan
            • 351
            you ever run a braswell carb? The have you run 6-6 1/2 at idle
            • hucktyson
              • 1903
              To bring up a sore subject yes in fact I have a mack daddy braswell 4825 4 circuit that I have sitting on my desk to use as a paper weight it has about 40 laps on it. Can you explain to me how exactly you have 6psi at idle and 7.5 at w.o.t without using a bypass style regulator and a return line ?
              • sj valley dave
                • 1016
                We have a 422" Sb2.2 and use the CV Products pump with a dead head and it never moves off 7 lbs of pressure. Great pump. And we have a 3 circuit 1.59 Venturi Braswell with a constant 7 lbs through it with zero problems...
                • spiderma4
                  • Dec 2009
                  • 91
                  thanks for the info, i can run off the back or onthe block. so the racepump pumps have issues?
                  • TALON75
                    • 887
                    Hey huck, what do you want for that paperwieght?
                    www.RACE91.com
                    • powerslide
                      • 2696
                      already tried to talk him out of it!!!
                      • hucktyson
                        • 1903
                        I talked to jack cornett about it and he said to send it back and he will get it fixed, so im sending it back and if that doesnt work out ill discuss selling it. After buying the carb, the 4825 specific air clearner and fuel long and running it 40 or so laps i am not about to sell it for half of what I paid , people were offering like $800.00 which isnt even half and thing this is in brand new condition. I am still stunned with the throttle response below 3500 rpm, I have never driven a crate car but this thing responded like id imagine a crate car would untill around 3500 then it was great untill you have the next restart. if sending it back fixes the issue i will be the first to come on here and say how great it is...
                        • hucktyson
                          • 1903
                          As a side note Jack warned me that the 4 circuit deal was not perfected yet and he recomended using a normal 2 circuit, but after talking to braswell at pri I was convinced this 4 circuit was going to be a low rpm restart monster which is what i was looking for and exactly the opposite was true. From what im understanding most people sent there 4 circuits back and had them made into standard 2 circuits to fix the problem.
                          • spiderma4
                            • Dec 2009
                            • 91
                            hucktyson is there any regulators that are better to use with the cv pump? thanks
                            • hucktyson
                              • 1903
                              The one cv products/spin makes is really nice, its a little on the expensive side but it works great and last forever
