How much slack is ok?
  • dfhotlm33c
    • Apr 2011
    • 224
    Going through car...for next year
    Appleton 3.4 rack
    when engine isn't running, the steering wheel will move about 10* either direction before the wheels move..
    examining closely, this slack isn't at the rack, as the input at the rack doesn't move when the steering wheel is turned through this range of slack motion..in other words, the slack seems to be generated strictly through the u-joints in the system..
    is this normal, or too much? do I need to rebuild the steering column?
  • sj valley dave
    • 1016
    Replace the u-joints in the shaft...simple to do and our driver really liked the feel much better when we did...Having the wheel move that much without doing anything is a strange feeling I would think...
    • hucktyson
      • 1903
      Appleton 3.4 rack
      What your feeling is the torsion bar in the servo twisting and its normal
      • hucktyson
        • 1903
        Appleton 3.4 rack
        If its actually 10 degrees thats pretty excessive if you take the shaft out and feel play in the joints then they should be replaced
        • sj valley dave
          • 1016
          When we replaced ours, the slack went to almost zero...10* is a ton of movement...imo
          • Palehorse
            • 91
            make sure set screw is tight too, mine loosened up and I thought it was bad u-joints.
            "And I looked, and behold a palehorse: and his name that sat on him was Death, and Hell followed with him." Rev 6:8
            • dfhotlm33c
              • Apr 2011
              • 224
              Thanks so much! Great ideas! I will check the set screws first..
