I'm considering having a big block chevy built for my late model. My engine builder is a huge fan of big blocks. I'm not sure if the extra weight will hurt the handling too much. Anyone run a bbc in there car?
Bbc
A couple thing to consider. #1 will it fit in your car? Also your gonna want to make spacers for your mid plate to take advantage of engine setback and get more of the weight behind the center line of the front suspension. The reason I say fit is because I know somebody that had both a gen x and a rayburn and it wouldn't fit in the gen x
I know a guy who ran a Zobel Scurve car years ago. He ran a aluminum BBC and had nothing but trouble with it. It had alot of universals in the steering shaft and headers were hard to get. But everyone used to run them in the 1970 and 1980's pretty much. I wouldnt do it but it would be pretty cool! Post pictures if you do it.
Not to sound stupid but why? Just because an engine builder wants to isn't a big reason to me. Weight and placement is always a big concern and with the torque and horsepower numbers from the more typical powerplants with less weight it seems to get me back to why real fast.Last edited by hpmaster; 01-08-2012, 09:18 AM.
I agree 100%.Originally posted by hpmaster View PostNot to sound stupid but why? Just because an engine builder wants to isn't a big reason to me. Weight and placement is always a big concern and with the torque and horsepower numbers from the more typical powerplants with less weight it seems to get me back to why real fast.Modern Day Spec Wedge Racing
I also agree with MB. Why? You can get more hp than you can hook up with a SBC and you do not have a 65 lb crank that you're having to spin up....People ran flat heads in the 50's, the fast guys were on 23* heads in the 80's, things change, why mess with it and all the headaches?? IMO
I agree. Find a good dirt motor builder who can tell you what he can do with certain sbc heads and a ballpark price for the motor. I would look around and find the best set of good used heads you can afford. An honest guy will let you get them checked out before you lay out the bucks. I run 415 inch 18 degree Brodix motors and wet sumps. Truth is I can run ok if I set up the car right and by July it's so dry slick I can't use over 200 of the 690hp anyways. I get them freshened at 1300 laps and change plugs every 10 nights. No I aint a big boy but every once in a while I surprise them big boys.Originally posted by dualdj1 View PostYeah, small block is the way to go. If you want more torque, build a big displacement small block, 420/430/etc. weight savings, availability of spare parts, on and on, many reasons to stick with small block.Last edited by hpmaster; 01-09-2012, 11:24 PM.
Edge engines experimented with a BBC last year at Port Royal I believe. That big Dude made more than 1000HP!!! Now having said that I see the Pro's and Con's, the weight and cost issues, but I wonder if a big cube BBC might live longer at less RPM than a wilder SBC??? Maybe more expense up front for the BBC, but maybe over the lifetime could be a savings with longevity. May not need to build a 1000 HP, but just enough to strike a balance. That Edge built engine car won a few races too. So maybe something to at least look at. JMO"If racing were easy, everybody would do it."
#77 Leon "Slick" Sells
Port Royal
I saw that big block run at Port Royal against other very high end small block cars and they couldn't keep up with it. That thing was wicked fast down the staights. Still agree though, small block would be the way to go 99% of the time.
What sort of track is Port Royal? Are there any videos on youtube of the BBC car running? Whose car was it in? ThanksOriginally posted by racer1355inpa View PostI saw that big block run at Port Royal against other very high end small block cars and they couldn't keep up with it. That thing was wicked fast down the staights. Still agree though, small block would be the way to go 99% of the time."If racing were easy, everybody would do it."
I have ran them on and off for years. Now if I was building both all aluminum brand new I would go with the sbc. The reason I always used them was cost, I could put 3k in a big block and keep up with 75% of the big dollar engines. And just like F22 mentioned I would only turn them 7k rpm to make them live. The bbc loves to eat valve's so if you would decide to try it keep cam lift below .700" and replace valve's and springs around 750 laps.
