Lower Control Arms
  • Code-man
    • Dec 2011
    • 4
    Lower Control Arms
    Which one is better one piece, solid strut two piece or rod end two piece? Has anyone made they own?
    Thanks
  • supercomet32
    • Jan 2009
    • 186
    I run a rod end two piece that works pretty well for me but am not against the solid strut two piece either
      The one-piece control arms are more rigid in construction.
      The only problem we have had since switching to one-piece is easily getting caster where we want it. Adjustments don't really do much to move the ball joint without putting the whole structure in a bind which I find undesirable. We are switching to slotted uppers with the slug inserts so that we can more easily make caster adjustments.
      Just my two cents.
      • talclipse
        • 738
        The bad thing about the one piece lowers is if you clip a tire and bend a strut tube the entire lower is junk. With a two piece lower you can slap a new strut tube on and be ready to go between races. As far as the deal with setting caster goes it is a major PITA to the point that I started cutting my one piece lowers apart and putting a turnbuckle in them so that I could more easily adjust the caster. Like Matt said though it can put stuff in a significant bind.
