Why do the alum on the nose follow the contour of the lights? You are covering alot of the plastic of the nose up when doing this.
Nose Construction
They trim the plastic off. They do it to make the nose more "shovel" shaped to catch more air. Sometimes you can see creases in the aluminum to help create that shape.Crew Chief "Tip of the day":
