What pressure would everyone recommend on a triple pass radiator, stewart stage 3 pump, jones one to one serpintine pullys
radiator cap
We run a 15% reduction with a Howe double pass, Adams pump on an aluminum open engine and run a 28-32 lb cap
Becarefull with the high pressure caps we tried a one higher then 28 lbs car ran cooler but the radiator hose blew up like a baloon. if you go higher make sure you do like the sprint cars do and use steel braided line you will be asking for trouble. But i agree 28 to 32 works fine.
