howe blue max a arms
  • ilustfordust
    • 135
    Do they make a 11 1/2 split one for bolt in balljoint for black front end rocket
  • stillfast
    • Oct 2007
    • 353
    a-arm
    Not sure on Howe, but I think Port City has them for a black front end car.
    • ilustfordust
      • 135
      Can you remove cross shaft to install inside frame on lf and run the screw in type
      • sj valley dave
        • 1016
        How do you remove the cross shaft? usually you have to cut the plate where the bolt in goes and then you can remove clips and pull shaft out...With a screw in type, not sure if that is doable...
        • TALON75
          • 887
          Howe makes them so the cross shaft can be removed and replaced . I like Joes a-arms because the a frame bolts to the cross shaft making it easier to bolt it to the inside .
          www.RACE91.com
          • ilustfordust
            • 135
            Rocket says run 15 degree and joes only makes 10 degree whats the difference
            • sobe92
              • 774
              5* of ball joint angle is the only difference. we run a joes with no issues
              • TALON75
                • 887
                Joe's will make it for you, pretty sure it won't cost anymore just takes a couple extra days. We run a blue front rocket without issue on the ten degree arms.
                www.RACE91.com
