Air Cleaner Under Hood
  • JOSHUA31
    • Nov 2007
    • 226
    I need your opinions on this...
    The way our body and engine/manifold came out the air cleaner top is just barely coming out of the hood. This made a nice sleak look but we are concerned about the performance and other issues this may cause? Give me your thoughts...
    Thanks
  • perfconn
    • 3636
    It will cost you a little hp by pulling in hot air
    • Rayburnt1
      • 117
      We have the same issue. We built an air box and put some rubber gasket on top to seal it to the hood, then punched some holes around it to suck air from the top.
      • leadorfollow
        • Mar 2010
        • 59
        BRC sells a Kool Air box with hood scoop. That's what we have on our car and it works very well
        • ckyracer00
          • 284
          do you have a link you can post please?
          • leadorfollow
            • Mar 2010
            • 59
            https://www.bernheiselracecars.com/store.php?cid=10
            the kool air box is in the top right and the hood scoop are on the bottom left. both are fiberglass. the box comes in black or white and the hood scoops comes in multiple colors. Hope this helps
            • C10
              • Nov 2008
              • 359
              If you are running IMCA, a cold air box, and any air cleaner spacer over 2 inches is illegal.
