using jet fuel
  • Tlangley
    • Jan 2011
    • 11
    using jet fuel
    Has anyone used jet fuel mixed down with 93? If so how do you mix it.
  • perfconn
    • 3573
    Jet fuel is kerosene.I assume you really mean aviation fuel which you can run.
    • joedoozer
      • 745
      But jet fuel sounds so much faster than crop duster fuel.
      Crew Chief "Tip of the day":
      • sj valley dave
        • 1016
        That's got the potential to be the next "hot" set up...Then we can talk about the drawbacks/benefits to JP1, JP4, JP5 or JP7...LOL Interestingly enough, JP4 is a 50/50 blend of kerosene and gasoline..LOL
        • smokey power
          • 73
          Jet fuel
          just member,jp1/kerosene(K1),is "O"octane/"anti knock compound", & av., gas today is no lead!!! Jet fuel programs are very sophisticated, & jet engines make their own compression pressure,"reason they were invented ", they will burn anything combustible. Smokey
          • Graff Spee
            • 881
            Next you will want to run Propane ! LOL If you want to play, try using some Propelene oxide! It is an oxegenizer.
            • dirty white boy
              • 1238
              i talked with a few reputable builders this week bout fuel,...none thought much of using AV gas,..one even said if ya cant afford to feed the dawg,..leave it at the pound...
              white trash motorsports
              • andy16
                • Jul 2009
                • 310
                i ran av gas for the entire season of 2010. i had to replace 16 ti valves beat the hell out of valve seats and wore the rings out in 8 races. i had pan pressure in 8 races w a drysump. was a stupid mistake. if your runing steel valves and steel seats w thick rings maybe can get away with it? i couldn on alum head ber. seat. the gas i ran was avgas100 low lead. the reason i tried it was that i had not that high compression 12 to 1 and it had lead in it and it was 3 dollars a gallon. in the long run would have been better to get the vp. always ran the 112 before and after w no trouble. dont use it man i know its tempting but really itl tear your stuff up.
                • C10
                  • Nov 2008
                  • 359
                  Andy is 100% correct. It is simply not made for the high heat and ground use of racing.
                  • sj valley dave
                    • 1016
                    AV gas is designed for a very narrow RPM range at altitude...I know that there are "millions" of people that have ran it for years in their race cars...Great..It is NOT designed for race engines..Good luck
                    • Chico
                      • 766
                      totally agree with No on avgas most of the people that get away with are a low enough comp ratio that 93 would have been beneficial jmo
                      my daughter my sailor my hero the next greatest generation is our men and women now in harms way Pray for them
                      • antidive
                        • 28
                        AV gas
                        100 ll and 110 sonoco are the same thing
                        • sj valley dave
                          • 1016
                          Wrong! Look at the molecular make up of the 2 fuels...jeez
                          • rubbinsracin
                            • Aug 2009
                            • 668
                            so in say a 602 or 604 you would be better off just running 93? we have been running our car on a mix of 1 gallon av to every 4 gallons 93. we have done this to raise the octane just a bit, to get closer to 95-98 or so. we were told that going up to a 110, which is the only fuel our track provides, would do us no good and we would possibly give up power. is this true?
                            • JustAddDirt
                              • 1893
                              fuel
                              Yes you would possibly lose some power because you do not have the compression to fire the fuel, correctly. those motors were designed for street use, so a 93-94 octane is all you should need. The 100ll avgas would be tops of the octane level you would need.
