ok. so in an efford to loose some weight weight we switched to an aluminum Jbar this year from the steel one that we had been using. obviously the steel jbar was alot smaller and there were no worries about clearance issues with the top of the jbar hitting the bottom of the top bar of the torque arm under cornering conditions(hope this makes sense) now with the aluminum one in place, even though it has the same amount of rise in the jbar, it is about a 1/3" or so from hitting the torque arm at static ride height due to the bar itself being thicker.
should we worry about the Jbar hitting the torque arm during cornering when the car is way up on the bars?
