What type of regulator are you guys using to fill gas shocks? The highest regulator I have only goes to 100PSI which isn't enough to fill my shocks. Just curious what people are using.
Nitrogen Regulator for shocks
Any air conditioning supply store will have a regulator. You will need to swap the fitting out to put an air coupler on it, but thats easy.Crew Chief "Tip of the day":
your local welding supply store will have what you need,they have them that go up to 300 or 400psi,be carefull and check your hose so that its rated for high pressure or it could blow up in your face,a very big safty hazard,ive seen it happen and if it got you just right it could kill ya (blow an air bubble under your skin with out knowing)so check your hose!!!
