just looking for some help with an oil leak that developed last weekend. running a 3 stage peterson dry sump with the breather tank to collect moister and started blowing oil out of the breather. ran the same system last year with no issues at all. put in a fresh motor to start the season and now we are blowing some oil out this breather. the only real difference in the motor from last year is the oil pan. the new motor has a champ pan on it and the oil lines hook to the top of the pan where the old motor had the oil lines attached to the botttom of the pan. also the new pan has 3 scavange lines where we are only using two ( using the front and back ones with the center capped off). just looking for any suggestions to try as weve never had this issue before
