torque arm
  • junebug
    • 363
    torque arm
    I have a modified and just curious what all u late model guys r running for torque arm spring/shock/ and location
  • joedoozer
    • 745
    300 spring, straight 3 valve shock (thinking of changing this to a 3-7). It's at 36" now, but I run it at 34" on 3/8 or shorter tracks.
    Crew Chief "Tip of the day":
    • rubbinsracin
      • Aug 2009
      • 668
      were the same as joe, but we run at 34'' all the time. we ran a 3-7 for a short while and i didnt care for it as i felt 7 was to much rebound. if we would have had a 3-5 that wasnt already being used on the car i might have tried it. we just stuck the straight 3 back on and never touch it.
      • junebug
        • 363
        What was the prob with all that rebound? Too tight on entry? And when u guys shortened it to 34stay did u change rate at all or stay with 300
        • joedoozer
          • 745
          I stayed the same. As long as I am getting a decent amount of travel, I am fine with keeping the same spring.
          • sj valley dave
            • 1016
            We normally keep it at 34"...On a big 1/2 mile we do move it out farther..We went to a straight 5 valve wand we run a 325 or 300 spring depending...
            • junebug
              • 363
              30.5 is the longest I can make it without it hitting the x...what changes would u make since I have to run it so short?
              • leadorfollow
                • Mar 2010
                • 59
                we start the night on a 3 on rebound and change to a 5 rebound once the track blows off. If it goes absolutely dead slick and I mean lock down on the bottom of the track we'll go to a 7 but that's very minimal.
