Would there be much of a market for 18* small block chevy steel heads?
18* sbc steel heads
I would think there could be a good market for them, be it circle track racing, drag racing or any other form providing the cost could be kept somewhat inline with the other steel heads out on the market now. But 99% of the people that will post on this topic will find some way to shoot holes in a new idea or just say there are enough products out there now, and this will be just another way to make engine builders rich. My opinion about the steel heads now is they seeem to be limited in the sense of how much you are able to get out of them. I personally think that steel heads are a good way to help control some of the cost, but I know of some engine builders in the Florida area that have built probably hundreds of steel head engines, and when you send the heads to a what I consider to be a very reputable and extremely good at what they do racing head service you end up with a set of 2500-3000 dollar heads because of limitations on the 23deg. steel heads out now. I think an 18deg. steel head would be a great idea because in theory there should be less machine time involved in getting a lot more performance out of an 18deg. cylinder head. This is just my opinion and I am sure it will be shot full of holes as well by people who have never been part of the racing industry and are keyboard performance experts.
Hey Terry, I think the question is how many classes are out there that you could use them...I know here in CA a lot of the iron head classes also have the 23* +/- one degree stipulation...I like the idea...For drag racing, where you might not have those restrictive rules, they might be a hot set up...
the weight is a big thing w/ them i think as well when you get below 23degree they start to get pretty heavy
I know alot of the asphalt modified guys in Florida parked their cars because of not really being able to afford the aluminum 18deg. or SB2 stuff. Having limited budgets and not being able to get the performance out of the 23deg. steel heads they have or can get their hands own. I have seen quite a few different sets of rules that allow weight breaks for steel head engines vs. alum. head engines, so there may be more of a market than one would initially think. I certainly wouldn't jump out there and have 15 or 20 sets on the shelf but may also be beneficial to find a guinea pig and try at least a set or two out onsome cars.
i dont think that would work at all... i have NEVER EVER seen a rule that said had to run steel heads that didn also say had to be 23* +or- 3* for angle milling. im pretty sure those 14* steel heads flopped for that very reason. when they first came out everyone was like oooooooh its a steel head and then they read the rules and was like oh yea 23*
Don't know how to copy and paste on this tablet but you can go to several websites such as: moulton raceway(2 barrel),greenvalley raceway(sportsman),boyds speedway and you will see that not all tracks have a + or - at all on their steelheads.
i may not understand. i looked at moulton rules. it didn give a degree and said you could angle mill. but it did say no aftermarket heads. so if you can angle mill it to 18* i guess itd be legal. but im pretty sure all you can get is three degrees and have it live for any amount of time.
