Hardening a tire
  • citiracer
    • May 2008
    • 233
    Hardening a tire
    Believe it or not, I would like to harden (not soften) a tire.
    Without the use of chemicals...
    Has anybody had any luck doing this? I thought about just soaking in cold water overnight. Not sure if that would work or not.
    Long story short, we are allowed two tires. One that is too soft come feature time and the other that is too hard and won't hardly get working in a 20 lap feature...especially if there are cautions.
    So I'm looking to harden the softer of the two tires.
  • TALON75
    • 887
    Get it muddy and leave it outside somewhere that gets sun but leave it out all the time, should make it harden up .
    www.RACE91.com
    • dirty white boy
      • 1238
      wash it down with rubbing alcohol an set in sun...
      white trash motorsports
      • TPR30
        • Jan 2011
        • 58
        Put them in a deep freezer
        • Graff Spee
          • 881
          All you have to do is heat cycle them a number of times. leaving them in the tire rack of an open trailer for a couple of weeks is a tried and true way.
          • joedoozer
            • 745
            Works for me....even when I don't want it to.
            Crew Chief "Tip of the day":
            • Egoracing
              • 4852
              Get it hot and then icewater it down. We had to do it to the Good Years we had to run in some events at some tracks. You are just quickening the heat cycle process.
