GRT spindle question
  • racer21
    • 190
    My car is 1063 and they said it was a late 97 early 98 and was built for buddie oliver,
    • racer21
      • 190
      Well back to the spindle deal,the spendle's on my car are 10.5 and 11 inches 11 n the left front is this correct and where's the best place to get replacement's thanks in advance
      sorry to sound like a big dummy im just not familer with the late model stuff,but do know mods only reason for the latemodel is the mods are dying out at local track and i don't
      like the expense of traveling 2 hours one way everyweek,thanks
      • mqdirtracer57
        • 493
        The heights sound correct. PPM in Tennessee has them at great prices...877-560-0619
          • 2020
          Spindles: If you want to get precise the LF is 10.875 and the RF is 10.125, however they will vary some (as much as .400" that I've measured over the years - all GRT manufactured spindles).
          414banger: you can check with GRT but numbers listed by other posters are correct. GRT did not ever start over with numbers, they did skip some numbers but never went backwards. They would assign a number to a car ordered and if the order was cancelled they didn't build one with that number.
          They build about 50 cars before they started numbering cars, I have owned several over the years and here are some numbers (appox) for certain years
          94 = 134
          95 = 354
          96 = 500-700+ (They built a lot of car this year)
          semi early 99 = 1214
          I think you are mistaken or got told something wrong as I'm 100% sure there is no way either of the 2 car numbers you listed could be anything newer then a 98. However the only way to find out is to call GRT. Hopefully if you were purposely mislead on the car you bought, maybe you can get something worked out with the seller.
          Good Luck
          • sj valley dave
            • 1016
            Unfortunately billetbirdcage is 100% correct...they never started over in their numbering system...there are some shenanigans going on with someone...IMO back to spindles, TWM made spindles for GRT for quite some time also
            • 414banger
              • Jun 2009
              • 354
              after further investigation the car is a 95 but ohwell it looks to be very well taken care of and never bent and has not been updated could anybody steer me toward a setup for this car as far as bar lenghts and such any help would be appreciated
              • racer21
                • 190
                414 good luck with trying to get any info from grt ive tryed several times and they always take my num and will call me back guess there calling the wrong num,what little bit you
                can get from these boards will be a big help i bet if i was ordering a new car grt would have time to talk,but if i ever do get a new one i promise it wont be grt!! good luck
                • washeduptoo
                  • 1353
                  See if BilletBirdcage will help you, he knows what he is talking about. Good luck.
                  • sj valley dave
                    • 1016
                    Does it still have the 16 5/8" LF and 17 5/8" RF lower arms and the long 10" upper arms on the inside of the uprights? Also rear links, 15" lower and 17" uppers with a 1/4" longer on right side?
                    • racer21
                      • 190
                      Yes sj you are correct it is excatly that,
                      • washeduptoo
                        • 1353
                        Sounds like SJ knows that car too.
                        • sj valley dave
                          • 1016
                          racer21...check your PM's..
                          • racer21
                            • 190
                            sj i have no messages,
                            • sj valley dave
                              • 1016
                              Don't know what happened... I'll try again
                              • sj valley dave
                                • 1016
                                I have no idea what is going on with this board!!...Just PM'd you again and it does not show sent in my box...We have an old 98 with 2008 updates front and rear...be happy to help you any way I can..we run in the Super Late Model class....e mail is sjvalleydave@yahoo.com if you have any questions...
