97 grt with traction afco shock
  • hobbyracerbn2
    • 113
    just wondering installin the traction shock on front birdcage before u scale car or after? its got 40 clicks where do i start on it thanx
  • jedclampit
    • 613
    Take it off and set it on the deck above while scaling.
    some people just unhook the lower mount....... and then forget to reinstall/tighten it and destroy it when they loadup or hit the track, take it off!
    You should be able to get a sheet that goes with the shock with baseline settings
    • hobbyracerbn2
      • 113
      i was wantin to know a little more bout this traction shock deal..is there alot of drivers usin this and had more success with it than not havin one...i mean how would u know when to adjust it? what would it do to the handling as more u keep addin more comp.
      • jedclampit
        • 613
        Traction shock is an inappropriate name, 'hike down control shock' would be a more appropriate name(probably won't sell as many although!)
        • drtrkr244
          • 1024
          A lot of teams are running just the rear shock now.
          You just need a specially valve shock to control the "hike down".
