What do you guys do to keep the dirt out of the left rear wheel? I've got to do somthing mine packs full and has almost worn through the LR brake caliper.
Dirt in the left rear wheel
They make those inserts to help block the mud. What about wiping down the rim with something to keep the mud from sticking?Crew Chief "Tip of the day":
Audie Swartz makes a bolt on piece that attaches to the LR brake caliper. You just bolt or rivet a small piece of plastic (like for your rocker panels) to this bracket and it lays against the inside back of the wheel. As the wheel turns, it keeps any dirt from building up.
Not sure how much the kit costs, but we bought one a few years ago and have ran it on our cars ever since. Works great.
Later,
WV Race Fan
I would think you might be able to take a 5 on 5 innner mud guard and put the wide 5 pattern in it.
Depending on your back space? I run 3 inch and they go out pretty far before they radius to the wheel.
I sell Aero LR wide 5 inner wheel covers . Will only work on a 5" offset wheel . It is a cover like the ones mods run . 563-659-1153 Dave. Ship UPS daily
we wipe the inside of the wheel down with wd40 before every race. no problems at all since we did this.
