Hi we have a 2008 masterbuilt i was wondering what we could do to tighten it up in the dry slick off the corner. it just not tight enough on throttle we run on a 1/4 mile semi backed track any ideas thanks.
drive off help
Posted it a million times, For drive from the center off on the gas drop the left bottom bar on the chassis, this rotates the birdcage into the spring/shock package faster and sooner while when the lift bar and comes into play during throttle application and body roll.
I'd try Ego's idea and see how that does for you. If not, try playing with the 5th possibly. I would maybe put some rebound in the 5th for when it goes to slick off and that should help you get some drive coming off the corner
I'm having the exact same problem. I'm good going in but gettih back on the gas I have nothing. Just no traction. I run 4 bar and I don't really understand what all 4 bars do. I kbow each one does something different.MYLES MOOS RACING
#20 Valvoline POWERED
read this:
More than 40 years ago, AFCO racing and performance parts first answered the simple need for better racing suspension. AFCO shocks and suspension components quickly earned a reputation for giving a racing team an advantage. Today, the AFCO advantage can be found in thousands of performance products.
I had that same problem, but I made adjustments to my 5th shock and it greatly improved. I moved it all the way up, and put a soft spring on mine, and whenever the track slicks off, I screwed the spanner nut on the 5th up a few rounds. This helped me a good deal getting on the throttle and gave it more foward drive/bite, and it also made the car squat on the RR more.Originally posted by moosie34 View PostI'm having the exact same problem. I'm good going in but gettih back on the gas I have nothing. Just no traction. I run 4 bar and I don't really understand what all 4 bars do. I kbow each one does something different.
good info. most of your forward is derived from 5th/pull bar.Originally posted by latemodel86 View PostI had that same problem, but I made adjustments to my 5th shock and it greatly improved. I moved it all the way up, and put a soft spring on mine, and whenever the track slicks off, I screwed the spanner nut on the 5th up a few rounds. This helped me a good deal getting on the throttle and gave it more foward drive/bite, and it also made the car squat on the RR more.
I thought you put turns in ur 5th coil to give more forward bite?Originally posted by latemodel86 View PostI had that same problem, but I made adjustments to my 5th shock and it greatly improved. I moved it all the way up, and put a soft spring on mine, and whenever the track slicks off, I screwed the spanner nut on the 5th up a few rounds. This helped me a good deal getting on the throttle and gave it more foward drive/bite, and it also made the car squat on the RR more.MYLES MOOS RACING
It's funny you say that. Last time I raced, I screwed the spannernut up when it got dry and slick, and it helped the car on throttle with foward drive. My buddy who told me to do that, recently just told me I can also screw the nut down on the 5th to help it like you just said, but I can't remember why he said it. I know it's contradicting, but that's what he told me. It's probably best not to listen to me, I'm just a teenager that loves dirt racing and is trying to help others off what little bit I know and my experiences. ha
